Adaptive Cross-Approximation (ACA)
The adaptive cross-approximation (ACA) is a fast method, similar to multilevel fast multipole method (MLFMM). The method improves the solution of certain complex method of moments (MoM) problems using less memory and run-time.
The ACA method does not suffer from low-frequency breakdown and is also applicable to using the special Green's function.
