Creating a Cylindrical / Circular Antenna Array
Create a cylindrical or circular finite antenna array model.
                On the Construct tab, in the Structures
                        group, click the
 Planes/Arrays icon. From the drop-down list, select the
 Cylindrical/Circular Array icon.
             - In the Radius field, enter the radius of the cylindrical / circular antenna array.
                Specify the elements in the phi dimension.
- Under Phi dimension, in the Number of elements field, specify the number of array elements.
 - Under Phi dimension, in the Specify increment field, specify the offset between the array elements.
                Specify the elements in the N dimension.
- Under N dimension, in the Number of elements field, specify the number of array elements.
 - Under N dimension, in the Offset along N axis field, specify the offset between the array elements.
                Specify the element rotation.
- To place the array elements with the same orientation as the base element, clear the Element orientation check box.
 - To rotate the array elements sequentially, select the Element orientation check box.
                In the Label field, add a unique label for the antenna
                    array.
Figure 1. The Create Cylindrical Circular Array dialog. -
                Click the Distribution tab to specify the array
                    distribution.
- To create an antenna array where the distribution is calculated from the plane wave (if a plane wave is present in the model), click the Uniform distribution or calculated from plane wave check box.
 - To create an antenna array with a specified excitation for each element,
                        clear the Uniform distribution or calculated from plane
                            wave check box.Note: When specifying each element, take note of the array element indexing.
Figure 2. Image depicting the array element indexing.- To specify the magnitude scaling and phase offset manually:
- In the Magnitude scaling field, specify the excitation magnitude for the individual element relative to the base element.
 - In the Phase offset (degrees) field, specify the phase offset (in degrees) for the individual element relative to the base element.
 - To specify the magnitude scaling and phase offset by importing the
                                points from file, click Import.
- In the File name field, browse for the file you want to import.
 - [Optional] In the Scale by field, enter a value to scale the points.
 - Under Delimiter, click the delimiter type you use in your file.
 - Click OK to close the Import Points dialog.
