Harness Description List (KBL) Specification
Cable harnesses are becoming increasingly complex with innovations in the automotive industry. Import a complex cable harness from a .kbl file using the “harness description list” (KBL) specification.
The following KBL1 entities are supported:
- Coordinates
- Cartesian_point
- Node
- Segment
- Routing
- Cable paths
- Cross sections
- Cable harnesses
- Contact_points
- Connector_occurrance
Note:
- Cross sections are read as single conductors and media properties are ignored.
- CADFEKO supports only a subset of the v2.3 KBL format.
- No manufacturing information, material information or proprietary information is parsed from the .kbl file.
1 Kabelbaumliste, the German translation for “harness description
list”.
