Creation History of a Geometry Part
Remove the creation history of a geometry part to reduce memory and processing time for complex models by converting it to a primitive part.
CADFEKO stores the creation history of every part, allowing you to modify the part at any point in the creation history, although the history may require a significant amount of memory and processing time for complex models.
For example, if a small component of a union operation is modified, CADFEKO needs to recreate the parent parts to re-execute the union. Since these are not stored at every level, it means constructing them again from the lowest level up. However, quite often a large part of the model remains unchanged.
For example, often the model of a specific motor vehicle will remain the same, but it is common to place different antennas on such a vehicle. As a result, it is not required to re-evaluate the vehicle each time a small part of the geometry is changed.
