Edges and Wires (Geometry)
Edges are the boundaries of faces. Wires are not associated with faces and are often referred to as “free edges”.
Figure 1. Select an edge in the 3D view to highlight the corresponding entry in the details tree. The converse is also true.
- Local mesh size
- Local wire radius
- Wire core medium (metallic, layered dielectric, impedance sheet)
- Coating (layered dielectric)
- Local mesh size
- Solution method
