Mesh Formats for Import
View the supported mesh formats for import.
CADFEKO imports most of the mesh formats1 by running PREFEKO and importing the resulting .fek file. Since these formats do not support specifying dielectric media, all segments, triangles and polygonal plates are imported as PEC structures in free space. Tetrahedra obtain the medium Unknown.
When importing .fek files, only the mesh parts (wire segments, triangles, polygonal plates and tetrahedra) are imported. Information regarding the solution configuration is completely ignored. Medium information and segment radii are retained during import.
The following mesh formats are supported for import:
    | Formats | File Format |
| Feko model | .fek |
| CADFEKO mesh | .cfm |
| Feko HyperMesh | .fhm |
| Femap neutral | .neu |
| NASTRAN | .nas |
| AutoCAD | .dxf |
| STL | .stl |
| PATRAN | .pat |
| ANSYS | .cdb |
| CONCEPT | .dat |
| ABAQUS | .inp |
| ASCII | |
| GiD | .msh |
| NEC data | .nec |
| I-DEAS universal format | .unv |
| Voxel | .raw, .txt |
