Configuration List
The configuration list displays all configurations in the model.
The panel is located to the left of the application window, just below the ribbon. A new model starts by default with a single standard configuration. The following configuration types are supported:
  • Standard configuration
  • Multiport S-parameter configuration
  • Characteristic modes configuration.
Tip: Multiple configurations allow you to perform efficient simulations using different configurations (different loads or sources) in a single model.
