Adding a Medium to the Media Library
Add a medium from your model to the media library. In a new model, you can then reuse the medium by adding it from the media library to your model.
  1. In the model tree, click the medium you want to add to the library.
  2. From the right-click context menu, select Add to library.
    The medium is added to the media library.
