Auto Meshing
The automatic mesh algorithm calculates and creates the mesh automatically once the frequency is set or local mesh settings are applied.
While the mesh is calculated by the automatic mesh algorithm, you can continue with setting up the model configuration. When geometry is transformed, no re-meshing is required since transforms are applied directly to the mesh. The automatic mesh algorithm also takes into account the proximity of other geometry or mesh to create a finer mesh.
While the mesh is being calculated, its status is indicated by a progress bar in the status bar.
For large models that takes a while to mesh, the automatic meshing may be disabled.
