A local mesh size can be set on a wire, edge, face or a region to influence the mesh
size.
The steps described below to define a local mesh size are
similar for wires, edges and regions.
In the model tree, select the relevant part.
In the details tree select the wire, edge, face or region
where you want to apply a local mesh setting.
Tip: Multiple entities can be selected and edited
simultaneously.
From the right-click context menu, click
Properties.
On the Modify Face dialog, click the
Meshing tab.
Enable local mesh size for the selected item.
Under Mesh size, select the Local mesh
size check box.
In the Mesh size field, enter a local mesh size.
Click OK to set the local mesh size and to close
the dialog.
Remesh the model to view the local mesh refinement.
Tip: Use a variable to define a local mesh size and simplify mesh
convergence investigations.
