Adjust the auto-generated mesh that is generated when the frequency is set or local
mesh settings are applied to the geometry.
Note:
- To generate a tetrahedral mesh, activate the FEM solution method.
- To generate a voxel mesh, activate the FDTD solution method.
Open the Modify Mesh dialog using one of the
following workflows:
- On the Mesh tab, in the
Meshing group, click the Modify Mesh icon.
- Press Ctrl+M to use the keyboard
shortcut.
Specify the mesh size.
- To create a mesh using automatic mesh sizes, in the Mesh
size field, from the drop-down list
select Coarse, Standard or
Fine.
- To create a mesh with a custom mesh size, in the Mesh
select Custom. Specify the lengths applicable to the
model.
- In the Triangle edge length field, specify
the triangle edge length.
- In the Wire segment length field, specify the
wire edge length.
- In the Tetrahedron segment length field,
specify the tetrahedron edge length.
- In the Voxel size field, specify the length
for the voxel width, depth and height.
Specify the global wire radius.
Note: A local mesh refinement takes precedence over global mesh settings.
Click OK to modify the mesh and to close the
dialog.
