Define an infinite planar multilayer substrate.
Some applications for infinite planar multilayer substrates are as follows:
- Add a PEC ground plane at the top and bottom layers to model a
stripline.
- Add a PEC ground plane at the bottom layer to model a microstrip.
- Use the substrate (without a PEC ground plane) to model real earth.
- Use a finite thickness substrate without any ground plane to model a printed
antenna (for example, a log-periodic antenna).
On the Construct tab, in the Structures
group, click the Planes/Arrays icon. From the drop-down list, select Plane / Ground.
From the Definition method
drop-down list, select Planar multilayer
substrate.
Under Infinite layers, specify the top and bottom
infinite layers:
In the Top layer medium
drop-down list, select the medium for the top layer
that extends into infinity.
In the Top layer ground plane
drop-down list, specify whether the top layer should
have a ground plane.
- If the top layer has no ground plane, select
None.
- To add a ground plane for the top layer, select
PEC.
In the Bottom layer medium
drop-down list, select the medium for the bottom
layer that extends into infinity.
Click Add to add an additional layer. Click
Remove to remove the selected layer from the
substrate.
For each layer:
From the Ground plane
drop-down list, select one of the following:
- To remove the PEC ground plane located below the current layer,
click None.
- To add a PEC ground plane located below the current layer, click
PEC.
Specify the layer thickness.
Specify the medium.
Note:
- The top layer and bottom layer extends into infinity.
- In the CADFEKO
GUI, the first layer is indexed as 0.
- In the CADFEKO API, the first layer is
indexed as 1.
In the Z-value at the top of layer 1 field, specify
where the top of layer 1 is located.
Click OK to define the infinite planar multilayer
substrate and close the dialog.
