Apply a FEM line port to a FEM region when using the finite element method
(FEM) solution method.
On the Source/Load tab, in the
Ports group, click the FEM Line Port icon.
Specify the port position using one of the following workflows:
- The edges (or a connected set of free edges that form a continuous
straight line) of the port. Under Specify port, click
as an edge.
- The start point and end point of the FEM line port (in global coordinates). Under
Specify port, click as
points.
[Optional] If the polarity of the port is to be reversed, select the
Reverse polarity check box.
In the Label field, add a unique label for the FEM line
port.
Click Create to create the port and to close the
dialog.
