An oversized mesh element is a triangle with an edge length larger that the specified
maximum edge length. Oversized mesh elements can lead to reduced accuracy in the
results.
Select the model or geometry part either in the model tree
or 3D view.
On the Mesh tab, in the
Find group, click the Oversized Elements icon.
Specify the parts to be searched for oversized mesh elements.
To search the full model, under Search, click
Entire model.
To search only the selected part of the model, under
Search, click
Selection.
Specify the mesh parts to be searched for oversized mesh elements.
To search only the simulation mesh, under Mesh
Scope, click Simulation.
To search only the model mesh, under Mesh Scope,
click Model.
To search both the model and simulation meshes, under Mesh
Scope, click Both.
In the Length field, enter a value that is taken as the
upper limit for the triangle edge length. Any triangle edge length longer than
this length will be marked as oversized.
Click OK to search for oversized mesh elements and to
close the dialog.
The result of the search is displayed in the Model Status and on the Message Details dialog.. A
hyperlink to the part containing the oversized mesh elements is also given in the
dialog.
