Sources
A source is used to excite or illuminate the model and cause current to flow.
Note: Sources can be specified globally or per configuration.
The following sources are supported:
- sources on ports
- voltage source
- current source
- waveguide source
- FEM modal source
- ideal sources
- plane wave
- electric dipole
- magnetic dipole
- impressed current
- equivalent sources
- near field source
- spherical modes source
- far field source
- printed circuit board (PCB) source
- solution coefficient source
