Apply a solution coefficient data definition and use as an impressed current source
        at a specified point in space.
                On the Source/Load tab, in the
                            Equivalent Sources group, click the
 Solution Coefficient icon.
                    Figure 1. The Create Solution Coefficient Source
                            dialog.
                In the Magnitude scale factor field, specify the scaling
                    factor.
                In the Phase offset (degrees) field, specify the phase
                    (in degrees) to be added to the phase of the currents.
                In the Solution coefficient data field, specify the
                    solution coefficient data to be used to define the solution coefficient
                    source.
                In the Position field, specify where the source is to be
                    placed.
                In the Label field, add a unique label for the solution
                    coefficient data source.
                Click the Create button to create the solution
                    coefficient source and to close the dialog.
