Apply the spin operation to rotate the selected geometry around an axis to create
surfaces or solids.
Select the geometry part that you want to spin.
On the Construct tab, in the Extend
group, click the Spin icon.
Under Origin, specify the origin around which the
geometry is spun.
Under Axis direction, specify the orientation of the
spin axis.
Under Rotation angle, specify the angle through which
the geometry is spun.
Click Create to spin the selected geometry and to
close the dialog.
