Defining Windscreen Elements on a Curved Work Surface
Define curved parameterised windscreen antenna elements on a specified work surface
by using surface lines, surface Bézier curves or an array of linearly spaced
lines.
Create a line in the curved work space.
On the Windscreen tab, in the
Create Surface Curve group, click the Surface Line icon.
Specify the Start point, End
point and Work surface.
Click Create to create the surface line
and to close the dialog.
Create a surface Bézier curve in the curved workspace.
Create Surface Curve group, click the Surface Bézier Curve icon.
Specify the Start point, Start
tangent point, End tangent point,
End point and Work
surface.
Click Create to create the surface Bézier
curve and to close the dialog.
Create an array of linearly-spaced lines in the curved workspace.
Create Surface Curve group, click the Surface Regular Lines icon.
Specify the Constant parameter, Start
corner point, End corner point,
Number of lines and the Work
surface.
Click Create to create the regular spaced
surface lines and close the dialog.
