Optimisation Using .pre File modifications
Use optimisation with modifications made in the .pre file in EDITFEKO.
The optimiser operates on solution requests specified in CADFEKO. However, for advanced users, it is possible to make use of the optimiser after making modifications to the .pre file in EDITFEKO.
The optimiser operates on the labels of the solution requests. These labels are usually created in CADFEKO, but are copied to the .pre file. The optimiser reads the labels from the .pre file.
Figure 1. A patch antenna on a finite substrate fed with a voltage source on a wire port.
The antenna is fed with a voltage source on a wire port. Unless edited by the user, the voltage source is created with a default label of VoltageSource1 in CADFEKO. When the CADFEKO model is saved, a .pre file is created by CADFEKO.
To open the .pre file, run EDITFEKO from within CADFEKO.
In EDITFEKO the .pre file contains an A1 card with the label, “MyCustomVoltageSource1” (label following after “**”), see Figure 2.
Figure 2. Screenshot of the A1 card (voltage source on a wire segment) in the .pre file.
Figure 3. A snippet of the impedance optimisation goal dialog using a custom label.
