Reversing the Axis Order
Change the order in which values are plotted along the axis of a Cartesian graphCartesian surface graph.
The axis order can be reversed for both the horizontal axis
and the vertical axis.
As an example, the vertical axis order of a Cartesian graphCartesian surface graph is reversed. The steps are similar for reversing the horizontal axis order.
