SAR (Specific Absorption Rate)
SAR does not have any special quantities or properties.
POSTFEKO can display specific absorption rate (SAR) values from near field calculations, but if spatial peak SAR of either an 1g or 10g cube is required, a SAR calculation must be requested.
When viewing SAR results on a graph, the power lost or dissipated per medium is displayed in an info box in the result palette.
