Adding Time Domain Results to a View
Add the time results to a 3D view or graph.
You must have already solved the model over the required
            frequency range and defined a suitable time signal.
        - Select the graph or 3D view to which you want to add time results.
 - On the Time analysis tab, in the Add time domain results group, click the relevant request type. From the drop-down list select the request.
