Filter
Continuous low pass, high pass, band pass or band stop IIR-filter of type CriticalDamping, Bessel, Butterworth or ChebyshevI
    Filter
Blocks/Continuous
This blocks models various types of filters:
low pass, high pass, band pass, and band stop filters
using various filter characteristics:
CriticalDamping, Bessel, Butterworth, Chebyshev Type I filters
By default, a filter block is initialized in steady-state, in order to avoid unwanted oscillations at the beginning. In special cases, it might be useful to select one of the other initialization options under tab "Advanced".
Typical frequency responses for the 4 supported low pass filter types are shown in the next figure:
The step responses of the same low pass filters are shown in the next figure, starting from a steady state initial filter with initial input = 0.2:
Obviously, the frequency responses give a somewhat wrong impression of the filter characteristics: Although Butterworth and Chebyshev filters have a significantly steeper magnitude as the CriticalDamping and Bessel filters, the step responses of the latter ones are much better. This means for example, that a CriticalDamping or a Bessel filter should be selected, if a filter is mainly used to make a non-linear inverse model realizable.
Typical frequency responses for the 4 supported high pass filter types are shown in the next figure:
The corresponding step responses of these high pass filters are shown in the next figure:
All filters are available in normalized (default) and non-normalized form. In the normalized form, the amplitude of the filter transfer function at the cut-off frequency f_cut is -3 dB (= 10^(-3/20) = 0.70794..). Note, when comparing the filters of this function with other software systems, the setting of "normalized" has to be selected appropriately. For example, the signal processing toolbox of MATLAB provides the filters in non-normalized form and therefore a comparison makes only sense, if normalized = false is set. A normalized filter is usually better suited for applications, since filters of different orders are "comparable", whereas non-normalized filters usually require to adapt the cut-off frequency, when the order of the filter is changed. See a comparison of "normalized" and "non-normalized" filters at hand of CriticalDamping filters of order 1,2,3:
Implementation
The filters are implemented in the following, reliable way:
  1. A prototype low pass filter with a cut-off angular frequency of 1 rad/s is constructed from the desired analogFilter and the desired normalization.
  2. This prototype low pass filter is transformed to the desired filterType and the desired cut-off frequency f_cut using a transformation on the Laplace variable "s".
  3. The resulting first and second order transfer functions are implemented in state space form, using the "eigen value" representation of a transfer function:
      // second order block with eigen values: a +/- jb
      der(x1) = a*x1 - b*x2 + (a^2 + b^2)/b*u;
      der(x2) = b*x1 + a*x2;
           y  = x2;
    The dc-gain from the input to the output of this block is one and the selected states are in the order of the input (if "u" is in the order of "one", then the states are also in the order of "one"). In the "Advanced" tab, a "nominal" value for the input "u" can be given. If appropriately selected, the states are in the order of "one" and then step-size control is always appropriate.
References
Tietze U., and Schenk C. (2002):
Halbleiter-Schaltungstechnik. Springer Verlag, 12. Auflage, pp. 815-852.
Filter_0
mo_analogFilter
analogFilter
Analog filter characteristics (CriticalDamping/Bessel/Butterworth/ChebyshevI)
Structure
mo_analogFilter/choice1
Filter with critical damping
Number
0
1
mo_analogFilter/choice2
Bessel filter
Number
0
1
mo_analogFilter/choice3
Butterworth filter
Number
0
1
mo_analogFilter/choice4
Chebyshev I filter
Number
0
1
mo_filterType
filterType
Type of filter (LowPass/HighPass/BandPass/BandStop)
Structure
mo_filterType/choice1
Low pass filter
Number
0
1
mo_filterType/choice2
High pass filter
Number
0
1
mo_filterType/choice3
Band pass filter
Number
0
1
mo_filterType/choice4
Band stop / notch filter
Number
0
1
mo_order
order
Order of filter
Scalar
mo_f_cut
f_cut
Cut-off frequency
Scalar
mo_gain
gain
Gain (= amplitude of frequency response at zero frequency)
Scalar
mo_A_ripple
A_ripple
Pass band ripple for Chebyshev filter (otherwise not used); > 0 required
Scalar
mo_f_min
f_min
Band of band pass/stop filter is f_min (A=-3db*gain) .. f_cut (A=-3db*gain)
Scalar
mo_normalized
normalized
= true, if amplitude at f_cut = -3db, otherwise unmodified filter
Scalar
true
false
mo_nx
nx
Scalar
mo_ncr
ncr
Scalar
mo_nc0
nc0
Scalar
mo_na
na
Scalar
mo_nr
nr
Scalar
mo_cr
cr
Vector
mo_c0
c0
Vector
mo_c1
c1
Vector
mo_r
r
Vector
mo_a
a
Vector
mo_b
b
Vector
mo_ku
ku
Vector
mo_k1
k1
Vector
mo_k2
k2
Vector
Filter_1
mo_init
init
Type of initialization (no init/steady state/initial state/initial output)
Structure
mo_init/choice1
No initialization (start values are used as guess values with fixed=false)
Number
0
1
mo_init/choice2
Steady state initialization (derivatives of states are zero)
Number
0
1
mo_init/choice3
Initialization with initial states
Number
0
1
mo_init/choice4
Initialization with initial outputs (and steady state of the states if possible)
Number
0
1
mo_x_start
x_start
Initial or guess values of states
Vector
mo_y_start
y_start
Initial value of output
Scalar
mo_u_nominal
u_nominal
Nominal value of input (used for scaling the states)
Scalar
Filter_2
mo_u
u
u
Structure
mo_u/fixed
fixed
Cell of scalars
true
false
mo_u/start
start
Cell of scalars
mo_y
y
y
Structure
mo_y/fixed
fixed
Cell of scalars
true
false
mo_y/start
start
Cell of scalars
mo_x
x
x
Structure
mo_x/fixed
fixed
Cell of vectors
true
false
mo_x/start
start
Cell of vectors
u
implicit
Connector of Real input signal
input
1
y
implicit
Connector of Real output signal
output
1
