MultiSensor
Sensor to measure current, voltage and power
    MultiSensor
Electrical/Analog/Sensors
This multi sensor measures current, voltage and instantaneous electrical power of a singlephase system and has a separated voltage and current path. The pins of the voltage path are pv and nv, the pins of the current path are pc and nc. The internal resistance of the current path is zero, the internal resistance of the voltage path is infinite.
MultiSensor_0
mo_i
i
i
Structure
mo_i/fixed
fixed
Cell of scalars
true
false
mo_i/start
start
Cell of scalars
mo_v
v
v
Structure
mo_v/fixed
fixed
Cell of scalars
true
false
mo_v/start
start
Cell of scalars
mo_power
power
power
Structure
mo_power/fixed
fixed
Cell of scalars
true
false
mo_power/start
start
Cell of scalars
pc
implicit
Positive pin, current path
input
1
nc
implicit
Negative pin, current path
output
1
pv
implicit
Positive pin, voltage path
input
2
nv
implicit
Negative pin, voltage path
output
2
i
implicit
Current as output signal
output
3
v
implicit
Voltage as output signal
output
4
power
implicit
Instantaneous power as output signal
output
5
