StepCurrent
Step current source
    StepCurrent
Electrical/Analog/Sources
This current source uses the corresponding signal source of the Modelica.Blocks.Sources package. Care for the meaning of the parameters in the Blocks package. Furthermore, an offset parameter is introduced, which is added to the value calculated by the blocks source. The startTime parameter allows to shift the blocks source behavior on the time axis.
StepCurrent_0
mo_I
I
Height of step
Scalar
mo_offset
offset
Current offset
Scalar
mo_startTime
startTime
Time offset
Scalar
StepCurrent_1
mo_v
v
v
Structure
mo_v/fixed
fixed
Cell of scalars
true
false
mo_v/start
start
Cell of scalars
mo_i
i
i
Structure
mo_i/fixed
fixed
Cell of scalars
true
false
mo_i/start
start
Cell of scalars
p
implicit
Positive electrical pin
input
1
n
implicit
Negative electrical pin
output
1
