SM_ReluctanceRotor
Synchronous induction machine with reluctance rotor and damper cage
Electrical/Machines/BasicMachines/SynchronousInductionMachines
Model of a three phase synchronous induction machine with reluctance rotor and damper cage.
Resistance and stray inductance of stator is modeled directly in stator phases, then using space phasor transformation. Resistance and stray inductance of rotor's squirrel cage is modeled in two axis of the rotor-fixed coordinate system. Both together connected via a rotor-fixed AirGap model. The machine models take the following loss effects into account:
- heat losses in the temperature dependent stator winding resistances
- optional, when enabled: heat losses in the temperature dependent damper cage resistances
- friction losses
- core losses (only eddy current losses, no hysteresis losses)
- stray load losses
Whether a damper cage is present or not, can be selected with Boolean parameter useDamperCage (default = true).
Default values for machine's parameters (a realistic example) are:
number of pole pairs p | 2 | |
stator's moment of inertia | 0.29 | kg.m2 |
rotor's moment of inertia | 0.29 | kg.m2 |
nominal frequency fNominal | 50 | Hz |
nominal voltage per phase | 100 | V RMS |
nominal current per phase | 50 | A RMS |
nominal torque | 46 | Nm |
nominal speed | 1500 | rpm |
nominal mechanical output | 7.23 | kW |
efficiency | 96.98 | % |
power factor | 0.497 | |
stator resistance | 0.03 | Ohm per phase at reference temperature |
reference temperature TsRef | 20 | °C |
temperature coefficient alpha20s | 0 | 1/K |
rotor resistance in d-axis | 0.04 | Ohm at reference temperature |
rotor resistance in q-axis | same as d-axis | |
reference temperature TrRef | 20 | °C |
temperature coefficient alpha20r | 0 | 1/K |
stator reactance Xsd in d-axis | 3 | Ohm per phase |
stator reactance Xsq in q-axis | 1 | Ohm |
stator stray reactance Xss | 0.1 | Ohm per phase |
rotor stray reactance in d-axis Xrds | 0.05 | Ohm per phase |
rotor stray reactance in q-axis Xrqs | same as d-axis | |
stator operational temperature TsOperational | 20 | °C |
damper operational temperature TrOperational | 20 | °C |
These values give the following inductances: | ||
stator stray inductance per phase | Xss/(2*pi*fNominal) | |
rotor stray inductance in d-axis | Xrds/(2*pi*fNominal) | |
rotor stray inductance in q-axis | Xrqs/(2*pi*fNominal) | |
main field inductance per phase in d-axis | (Xsd-Xss)/(2*pi*fNominal) | |
main field inductance per phase in q-axis | (Xsq-Xss)/(2*pi*fNominal) |
mo_p | p | Number of pole pairs (Integer) | Scalar | |
mo_fsNominal | fsNominal | Nominal frequency | Scalar | |
mo_TsOperational | TsOperational | Operational temperature of stator resistance | Scalar | |
mo_Jr | Jr | Rotor's moment of inertia | Scalar | |
mo_useSupport | useSupport | Enable / disable (=fixed stator) support | Number | 0 |
mo_Js | Js | Stator's moment of inertia | Scalar | |
mo_useThermalPort | useThermalPort | Enable / disable (=fixed temperatures) thermal port | Number | 0 |
mo_pi | pi | Scalar | ||
mo_TrOperational | TrOperational | Operational temperature of (optional) damper cage | Scalar |
mo_Rs | Rs | Stator resistance per phase at TRef | Scalar | |
mo_TsRef | TsRef | Reference temperature of stator resistance | Scalar | |
mo_alpha20s | alpha20s | Temperature coefficient of stator resistance at 20 degC | Scalar | |
mo_Lszero | Lszero | Stator zero sequence inductance | Scalar | |
mo_Lssigma | Lssigma | Stator stray inductance per phase | Scalar | |
mo_Lmd | Lmd | Stator main field inductance per phase in d-axis | Scalar | |
mo_Lmq | Lmq | Stator main field inductance per phase in q-axis | Scalar | |
mo_useDamperCage | useDamperCage | Enable / disable damper cage | Scalar | true |
mo_Lrsigmad | Lrsigmad | Damper stray inductance in d-axis | Scalar | |
mo_Lrsigmaq | Lrsigmaq | Damper stray inductance in q-axis | Scalar | |
mo_Rrd | Rrd | Damper resistance in d-axis at TRef | Scalar | |
mo_Rrq | Rrq | Damper resistance in q-axis at TRef | Scalar | |
mo_TrRef | TrRef | Reference temperature of damper resistances in d- and q-axis | Scalar | |
mo_alpha20r | alpha20r | Temperature coefficient of damper resistances in d- and q-axis | Scalar |
mo_frictionParameters | frictionParameters | Friction loss parameter record | FromModelica('Modelica.Electrical.Machines.Losses.FrictionParameters') | |
mo_statorCoreParameters | statorCoreParameters | Stator core loss parameter record; all parameters refer to stator side | FromModelica('Modelica.Electrical.Machines.Losses.CoreParameters') | |
mo_strayLoadParameters | strayLoadParameters | Stray load loss parameter record | FromModelica('Modelica.Electrical.Machines.Losses.StrayLoadParameters') |
mo_phiMechanical | phiMechanical | phiMechanical | Structure | |
mo_phiMechanical/fixed | fixed | Cell of scalars | true | |
mo_phiMechanical/start | start | Cell of scalars | ||
mo_wMechanical | wMechanical | wMechanical | Structure | |
mo_wMechanical/fixed | fixed | Cell of scalars | true | |
mo_wMechanical/start | start | Cell of scalars | ||
mo_tauElectrical | tauElectrical | tauElectrical | Structure | |
mo_tauElectrical/fixed | fixed | Cell of scalars | true | |
mo_tauElectrical/start | start | Cell of scalars | ||
mo_tauShaft | tauShaft | tauShaft | Structure | |
mo_tauShaft/fixed | fixed | Cell of scalars | true | |
mo_tauShaft/start | start | Cell of scalars | ||
mo_vs | vs | vs | Structure | |
mo_vs/fixed | fixed | Cell of vectors | true | |
mo_vs/start | start | Cell of vectors | ||
mo_is | is | is | Structure | |
mo_is/fixed | fixed | Cell of vectors | true | |
mo_is/start | start | Cell of vectors | ||
mo_i_0_s | i_0_s | i_0_s | Structure | |
mo_i_0_s/fixed | fixed | Cell of scalars | true | |
mo_i_0_s/start | start | Cell of scalars | ||
mo_idq_ss | idq_ss | idq_ss | Structure | |
mo_idq_ss/fixed | fixed | Cell of vectors of size 2 | true | |
mo_idq_ss/start | start | Cell of vectors of size 2 | ||
mo_idq_sr | idq_sr | idq_sr | Structure | |
mo_idq_sr/fixed | fixed | Cell of vectors of size 2 | true | |
mo_idq_sr/start | start | Cell of vectors of size 2 | ||
mo_idq_rs | idq_rs | idq_rs | Structure | |
mo_idq_rs/fixed | fixed | Cell of vectors of size 2 | true | |
mo_idq_rs/start | start | Cell of vectors of size 2 | ||
mo_idq_rr | idq_rr | idq_rr | Structure | |
mo_idq_rr/fixed | fixed | Cell of vectors of size 2 | true | |
mo_idq_rr/start | start | Cell of vectors of size 2 | ||
mo_ir | ir | ir | Structure | |
mo_ir/fixed | fixed | Cell of vectors of size 2 | true | |
mo_ir/start | start | Cell of vectors of size 2 | ||
mo_idq_dr | idq_dr | idq_dr | Structure | |
mo_idq_dr/fixed | fixed | Cell of vectors of size 2 | true | |
mo_idq_dr/start | start | Cell of vectors of size 2 |
flange | implicit | Shaft | input | 1 |
plug_sp | implicit | Positive stator plug | input | 2 |
plug_sn | implicit | Negative stator plug | output | 1 |
Port 4 | implicit | Support at which the reaction torque is acting | input | mo_useSupport |
Port 5 | implicit | input | mo_useThermalPort |
