AIM_SquirrelCageData
Common parameters for asynchronous induction machines with squirrel cage
Electrical/Machines/Utilities/ParameterRecords
Basic parameters of asynchronous induction machines with squirrel cage are predefined with default values.
mo_Jr | Jr | Rotor's moment of inertia | Scalar | |
mo_Js | Js | Stator's moment of inertia | Scalar | |
mo_p | p | Number of pole pairs (Integer) | Scalar | |
mo_fsNominal | fsNominal | Nominal frequency | Scalar | |
mo_effectiveStatorTurns | effectiveStatorTurns | Effective number of stator turns | Scalar |
mo_Rs | Rs | Stator resistance per phase at TRef | Scalar | |
mo_TsRef | TsRef | Reference temperature of stator resistance | Scalar | |
mo_alpha20s | alpha20s | Temperature coefficient of stator resistance at 20 degC | Scalar | |
mo_Lszero | Lszero | Stator zero sequence inductance | Scalar | |
mo_Lssigma | Lssigma | Stator stray inductance per phase | Scalar | |
mo_Lm | Lm | Stator main field inductance per phase | Scalar | |
mo_Lrsigma | Lrsigma | Rotor stray inductance per phase (equivalent three phase winding) | Scalar | |
mo_Rr | Rr | Rotor resistance per phase (equivalent three phase winding) at TRef | Scalar | |
mo_TrRef | TrRef | Reference temperature of rotor resistance | Scalar | |
mo_alpha20r | alpha20r | Temperature coefficient of rotor resistance at 20 degC | Scalar |
mo_frictionParameters | frictionParameters | Friction loss parameter record | FromModelica('Modelica.Electrical.Machines.Losses.FrictionParameters') | |
mo_statorCoreParameters | statorCoreParameters | Stator core loss parameter record; all parameters refer to stator side | FromModelica('Modelica.Electrical.Machines.Losses.CoreParameters') | |
mo_strayLoadParameters | strayLoadParameters | Stray load losses | FromModelica('Modelica.Electrical.Machines.Losses.StrayLoadParameters') |
