VoltageQuasiRMSSensor
Continuous quasi voltage RMS sensor for multi phase system
Electrical/MultiPhase/Sensors
This sensor determines the continuous quasi RMS value of a multi phase voltage system, representing an equivalent RMS voltage V
vector or phasor. If the voltage waveform deviates from a sine curve, the output of the sensor will not be exactly the average RMS value.
V = sqrt(sum(v[k]^2 for k in 1:m)/m)
mo_m | m | Number of phases | Scalar |
mo_v | v | v | Structure | |
mo_v/fixed | fixed | Cell of vectors | true | |
mo_v/start | start | Cell of vectors | ||
mo_i | i | i | Structure | |
mo_i/fixed | fixed | Cell of vectors | true | |
mo_i/start | start | Cell of vectors | ||
mo_V | V | V | Structure | |
mo_V/fixed | fixed | Cell of scalars | true | |
mo_V/start | start | Cell of scalars |
plug_p | implicit | Positive polyphase electrical plug with m pins | input | 1 |
plug_n | implicit | Negative polyphase electrical plug with m pins | output | 1 |
V | implicit | Continuous quasi RMS of voltage | output | 2 |
