SymmetricMultiPhaseWinding
Symmetric winding model coupling electrical and magnetic domain
Magnetic/FundamentalWave/BasicMachines/Components
The symmetrical multi phase winding consists of a symmetrical winding resistor, a zero inductor as well as a symmetrical multi phase electromagnetic coupling and a stray reluctance and a core loss model including heat port.
See also
SinglePhaseWinding, SymmetricMultiPhaseCageWinding, SaliencyCageWinding RotorSaliencyAirGap
mo_useHeatPort | useHeatPort | Enable / disable (=fixed temperatures) thermal port | Number | 0 |
mo_RRef | RRef | Winding resistance per phase at TRef | Scalar | |
mo_TRef | TRef | Reference temperature of winding | Scalar | |
mo_alpha20 | alpha20 | Temperature coefficient of winding at 20 degC | Scalar | |
mo_alphaRef | alphaRef | Scalar | ||
mo_TOperational | TOperational | Operational temperature of winding | Scalar | |
mo_Lsigma | Lsigma | Winding stray inductance per phase | Scalar | |
mo_Lzero | Lzero | Zero sequence inductance of winding | Scalar | |
mo_effectiveTurns | effectiveTurns | Effective number of turns per phase | Scalar | |
mo_GcRef | GcRef | Electrical reference core loss reluctance | Scalar | |
mo_nBase | nBase | Number of base systems | Scalar | |
mo_mBase | mBase | Number of phase of the base systems | Scalar |
mo_v | v | v | Structure | |
mo_v/fixed | fixed | Cell of vectors | true | |
mo_v/start | start | Cell of vectors | ||
mo_i | i | i | Structure | |
mo_i/fixed | fixed | Cell of vectors | true | |
mo_i/start | start | Cell of vectors | ||
mo_abs_V_m | abs_V_m | abs_V_m | Structure | |
mo_abs_V_m/fixed | fixed | Cell of scalars | true | |
mo_abs_V_m/start | start | Cell of scalars | ||
mo_arg_V_m | arg_V_m | arg_V_m | Structure | |
mo_arg_V_m/fixed | fixed | Cell of scalars | true | |
mo_arg_V_m/start | start | Cell of scalars | ||
mo_abs_Phi | abs_Phi | abs_Phi | Structure | |
mo_abs_Phi/fixed | fixed | Cell of scalars | true | |
mo_abs_Phi/start | start | Cell of scalars | ||
mo_arg_Phi | arg_Phi | arg_Phi | Structure | |
mo_arg_Phi/fixed | fixed | Cell of scalars | true | |
mo_arg_Phi/start | start | Cell of scalars |
plug_p | implicit | Positive plug | input | 1 |
plug_n | implicit | Negative plug | output | 1 |
port_n | implicit | Negative complex magnetic port | output | 2 |
port_p | implicit | Positive complex magnetic port | input | 2 |
Port 5 | implicit | Heat ports of winding resistors | input | mo_useHeatPort |
Port 6 | implicit | Heat port of core | input | mo_useHeatPort |
