SpringDamper
Linear 1D translational spring and damper in parallel
    SpringDamper
Mechanics/Translational/Components
A spring and damper element connected in parallel. The component can be connected either between two sliding masses to describe the elasticity and damping, or between a sliding mass and the housing (model Fixed), to describe a coupling of the sliding mass with the housing via a spring/damper.
SpringDamper_0
mo_c
c
Spring constant
Scalar
mo_d
d
Damping constant
Scalar
mo_s_rel0
s_rel0
Unstretched spring length
Scalar
mo_useHeatPort
useHeatPort
=true, if heatPort is enabled
Number
0
1
SpringDamper_1
mo_stateSelect
stateSelect
Priority to use s_rel and v_rel as states
Structure
mo_stateSelect/choice1
StateSelect.never
Number
0
1
mo_stateSelect/choice2
StateSelect.avoid
Number
0
1
mo_stateSelect/choice3
StateSelect.default
Number
0
1
mo_stateSelect/choice4
StateSelect.prefer
Number
0
1
mo_stateSelect/choice5
StateSelect.always
Number
0
1
mo_s_nominal
s_nominal
Nominal value of s_rel (used for scaling)
Scalar
SpringDamper_2
mo_s_rel
s_rel
s_rel
Structure
mo_s_rel/fixed
fixed
Cell of scalars
true
false
mo_s_rel/start
start
Cell of scalars
mo_v_rel
v_rel
v_rel
Structure
mo_v_rel/fixed
fixed
Cell of scalars
true
false
mo_v_rel/start
start
Cell of scalars
mo_f
f
f
Structure
mo_f/fixed
fixed
Cell of scalars
true
false
mo_f/start
start
Cell of scalars
mo_lossPower
lossPower
lossPower
Structure
mo_lossPower/fixed
fixed
Cell of scalars
true
false
mo_lossPower/start
start
Cell of scalars
flange_a
implicit
Left flange of compliant 1-dim. translational component
input
1
flange_b
implicit
Right flange of compliant 1-dim. translational component
output
1
Port 3
implicit
Optional port to which dissipated losses are transported in form of heat
input
mo_useHeatPort
