You can add or delete connectors on many most blocks. If you delete a connector with an attached wire, the wire is also deleted.
Because additional connectors are unconnected in compound blocks, make sure you verify the input and output connections after you complete this procedure.
To add or remove connectors
1. Do one of the following:
•Press CTRL+ or CTRL-.
•From the toolbar, choose
or
•Choose Edit > Add Connector or Edit > Remove Connector.
2. Do one of the following:
•To add a connector: Point to where you want the connector and click.
•To delete a connector: Point to the connector to be deleted and click.
3. Repeat step 2 for as many connectors that you want to add or delete.
4. To exit this command, click on empty screen space.
