The Edit > Preferences command also lets you add and remove add-ons by inserting the corresponding DLL in the Addons window. Note that if a DLL uses the set user menu function (which allows the blocks contained in the DLL to be inserted into menus), you must insert the DLL in the Addons window. Also, all generated DLLs automatically include the set user menu function. Hence, you must include the DLL in the Addons window to access the C-code-generated blocks in the menus.
To add a DLL
After you add the DLL, the blocks contained in the DLL are automatically added to the menus.
1. Choose Edit > Preferences and click on Addons tab.
2. In the Addon List, double-click ....
The Open dialog box appears.
3. Select the DLL to be added into the Addons window and click Open.
In the Addons window, the complete path of the DLL is displayed.
4. Click OK, or press ENTER.
To remove a DLL
1. Choose Edit > Preferences and click on the Addons tab.
2. In the Addon List, select the DLL to be removed and click Delete.
3. Restart Embed to see the change..
