Creating a specific wiring a path
Using wirePositioner blocks, you can perform a connect-the-dot method of wiring. That is, you insert wirePositioner blocks and then manually route the wire through them. Since you control the placement of the wirePositioner blocks, it’s easy to draw a precise wiring path.
Additionally, because wirePositioner blocks do not take any additional computation time, you won’t see a decrease in performance during a simulation.
Displaying signal values
When you point to a connector and hold down the right mouse button, the signal value and data type are displayed next to the block.
