If you have more than one transition coming from a given state, the transitions will be numbered according to the evaluation order. Transitions with lower numbers have higher priorities.
To change the evaluation order
1. Right-click one of the transitions.
2. In the pop-up menu, select Reorder Transitions.
3. Click the transitions in the order you want them evaluated.
