You can edit an embedded object directly from Embed, or you can invoke the application as a separate, stand-alone program. To update the embedded object and return to the Embed environment, simply click outside the OLEobject block.
To edit an embedded object directly from Embed
1. Right-click the embedded object.
2. From the drop-down menu, choose Object > Edit.
3. Embed opens a window with the application file.
4. Make the changes you want.
5. Click outside the embedded object to update the object and return to Embed.
To invoke the object as a stand-alone application
2. From the drop-down menu, choose Object > Open.
A stand-alone window is opened with the application file.
3. Make the changes you want.
4. To update the object and return to Embed, do the following:
a. Choose File > Update.
b. Choose File > Exit and Return to.
