After you insert a PSIMCoupler block into your diagram, you can configure it to link a specific PSIM schematic to the diagram.
1. Right-click the PSIMCoupler block.
2. Under the Main tab, next to PSIM File Path text box, click … to select the PSIM schematic to be linked to the diagram.
3. Click OK to link the PSIM schematic to the Embed diagram.
The PSIMCoupler block is propagated with the inputs and outputs from the linked PSIM schematic.
Before linking to diagram |
After linking to diagram |
4. Wire the PSIMCoupler block into the Embed diagram.
