When you select Perspective Based on a Field of View, the following Projection Parameters are available:
Field of View: Indicates the field of view in the y direction. Specify this value in radians.
Aspect Ratio: Specifies the view space width divided by height.
Z-Value of the Near View-Plane: Specifies the Z-value of the near view-plane.
Z-Value of the Far View-Plane: Specifies the Z-value of the far view-plane.
