Flag |
Description |
VBF_ALLOC_VEC_OUTPUT |
Causes Embed to automatically allocate output matrix for matrix input blocks. |
VBF_ALLOW_VEC_CHAMELIONS |
Causes connectors to accept scalar or vector connections. |
VBF_CANCEL_DLG |
Reserved. |
VBF_CG_BLK_HAS_NO_RETURN_VALUE |
If your DLL has one output, set this if you do not want to use a function return value. |
VBF_CG_BLK_HAS_RETURN_VALUE |
Reserved. |
VBF_CG_EVENT_FUNC |
Allows code generation for your DLL event function. |
VBF_CG_NEVER |
Prevents block from generating code. |
VBF_EXECUTE_ALWAYS |
Executes the block regardless of graph connectivity. |
VBF_EXECUTE_NEVER |
Never executes the block. |
VBF_HAS_STATE |
Indicates that the block has state and can break an algebraic loop. This block is called once, before all other blocks, to present an initial condition; then the block is called during normal diagram execution. |
VBF_MENU_ONLY |
Indicates a menu item only and no block is created; however, the userBlockEvent() function is called. This flag is useful for menu select to dialog. |
VBF_RUN_BLOCK_AT_FRAME_END |
Reserved. |
VBF_STRAIGHT_WIRES |
Causes wires to be drawn as straight lines rather than auto-routing. |
VBF_USE_SIGNAL_DESCRIPTORS |
Indicates block input and output vectors are of type SIGNAL (not double). |
