When you only care about the final results of a simulation and you are not interested in looking at the simulation graphically, you may want to create a BAT file that contains command line arguments to start Embed with a specific diagram and execute the diagram without user interference.
To create a BAT file
•Use any editor to create a BAT file that contains the following:
<install-directory>\vissim32.exe -arg1 -arg2 -arg3… complete-path-to-block-diagram.vsm
If you enter more than one argument, separate them with spaces. The diagram name must be specified last.
To execute the batch file
•In the Windows Explorer, double-click the BAT file name
•At an MS-DOS shell prompt, enter the BAT file name
