You can alternatively start Embed with command line arguments in an MS-DOS shell. Starting Embed from an MS-DOS shellt provides these capabilities:
•You can invoke Embed from another application
•You can run Embed in the background
To start Embed from an MS-DOS shell prompt
1. Start an MS- DOS shell.
2. Navigate to the Embed install directory.
3. Start Embed by entering
<install-directory>vissim32 –arg1 -arg2 -arg3… [complete-path-to-block-diagram.vsm]
If you enter more than one argument, separate them with spaces. If a diagram name is included in the argument list, it must be specified last.
