In designing each compensator, the following system characteristics hold true:
•LM = Log magnitude, base 10
Cross-over frequency of open-loop Bode
LM plot
Phase margin of open-loop Bode
phase plot
Time constant, s
Damping ratio
The open-loop Bode frequency response can be used to approximate closed-loop system behavior, provided the open-loop frequency response satisfies three conditions:
•The gain at low frequencies is relatively high for low steady-state errors
•The gain at high frequencies is relatively low for disturbance attenuation
•The slope of the Bode plot is approximately
When the above conditions are approximately satisfied, the following correlations are valid:
