Use point entry to add the coordinates of a named point in the model tree to fields on a dialog.
As an example, specify the base corner of a cuboid using point entry to add the
coordinates of the named point (in the model tree) to the dialog.
Open the Create cuboid dialog.
Verify that the Base corner field is highlighted in
yellow.
Press and hold down the Ctrl+Shift keys while
hovering with the mouse cursor over a named point in the model tree.
Left click on a named point in the model tree to perform point
entry on the named point. You can now release the Ctrl+Shift keys.
The coordinate of the named point is added to the Base
corner fields and the focus has moved to the next
field.
