Spin
Rotationally sweep a geometry part, containing only edges and faces (not solids or closed regions), around an axis through a specified angle.
The spin operation applied to lines produces faces and to faces produces volumes. For
surface bodies, the body must have a single boundary which does not close on itself and
no edge may be attached to more than two faces.
Note: The spin
operation is applied separately to each of the selected geometry parts.
