Adding a Result from the Ribbon
Add a result to a 3D view or graph using the ribbon.
  1. Select the 3D view or graph where you want to add a simulation result.
  2. On the Home tab, in the Add results group, click the relevant icon (if results are available).
  3. If more than one result of the same request type are available, select a result.
    Figure 1. Example of adding a far field result from the ribbon and selecting a specific result.
  4. If multiple models are loaded into the same session, POSTFEKO will collapse the panel.
  5. [Optional] Click Show more entries to view all the available results.
