Move the display of the far field origin to be more consistent with the location of
the source.
Far fields are displayed in POSTFEKO around the global
origin. When the source of the radiator is located away from the origin, the far field
origin can be moved to show a more intuitive result.
Select the 3D view and far field result that you want to
modify.
On the 3D View contextual tabs set, on the
Result tab, in the Rendering group, click the Offset icon.
On the Set display offset dialog specify new values for
the U, V and N coordinates.
Tip: You can use Ctrl+Shift+left click to
click on the new origin for the far field.
Figure 1. A dipole and PEC structure with a far field with no offset (on the
left) and a far field with an offset (to the right).
