Check |
Level |
Correction |
Option Cards |
Check random noise. Preferably set it equal to 0. (Especially important when using the Engine option /DEL/INTER.) |
Delete (set to 0). |
Gravity Cards |
Number of gravities. |
Number of duplicate gravity card ID. |
Automatic correction. |
Material Cards |
Number of MIDs. |
Number of duplicate MIDs. |
Number of unused MIDs. |
Automatic delete. |
Number of TH-selected MIDs. |
Check the order of the strain rate in the material law 36 (/MAT/LAW36). |
Node Cards |
Number of nodes. |
Number of duplicate nodes ID. |
Number of TH-selected nodes. |
Number of free nodes. |
Boundary Condition Cards |
Number of boundary conditions. |
Number of duplicate boundary card ID. |
Skew Frame Cards |
Number of skew frames. |
Number of duplicate skew card ID. |
Number of skew frames not correctly defined. |
Brick Element Cards |
Number of brick elements. |
Number of duplicate brick element identifier numbers. |
Number of duplicate brick elements. |
Incorrect orientation and normal direction (negative volume). |
Number of TH-selected brick elements. |
4-Nodes Solid Element Card |
Number of tetrahedron elements (TETRA4). |
Number of duplicate tetrahedron elements. |
Number of duplicate tetrahedron element identifier numbers. |
Pentahedron Solid Element Cards (PENTA6) |
Number of pentahedron elements. |
Number of duplicate pentahedron elements. |
Number of duplicate pentahedron element identifier number. |
Quadratic Brick Element Cards (BRIC20) |
Number of quadratic brick elements. |
Number of duplicate quadratic brick element identifier number. |
Number of duplicate quadratic brick elements. |
Quadratic Thickshell Element Cards (SHEL16) |
Number of quadratic thickshell elements. |
Number of duplicate quadratic thickshell element identifier number. |
Number of duplicate quadratic thickshell elements. |
Quadratic Tetrahedron Element Cards (TETRA10) |
Number of quadratic tetrahedron elements. |
Number of duplicate quadratic tetrahedron element identifier number. |
Number of duplicate quadratic tetrahedron elements. |
4-Node Shell Element Cards |
Number of 4-node shell elements. |
Number of degenerated SHELL4N elements. |
Convert to SH3N. |
Number of duplicate 4-node shell elements. |
Number of TH-selected 4-node shells. |
Segment common to 3-shell elements. |
Detection of the meshing where hourglass deformation mode might occur. |
3-Node Shell Element Cards |
Number of 3-node shell elements. |
Number of duplicate 3-node shell elements. |
Number of TH-selected 3-node shells. |
Shell Element Cards (3 and 4 Nodes) |
Thickness defined on the element cards. |
Automatic correction: remove the thickness value from the shell element. |
Truss Element Cards |
Number of truss elements. |
Number of duplicate truss elements. |
Number of loose truss nodes. (If one or two of the nodes defining the truss are not connected to another element or a rigid body). |
Open page, Mesh-Editing / Element / Modify |
Number of loose truss nodes. (If one or two of the nodes defining the truss are only connected to a same type and same property element). |
Maximum and minimum length of truss and IDs. |
Number of TH-selected trusses. |
Beam Element Cards |
Number of beam elements. |
Number of duplicate beam elements. |
Number of loose beam nodes. (If one or two of the nodes defining the beam are not connected to another element or an RB.) |
Number of loose beam nodes. (If one or two of the nodes defining the beam are only connected to a same type and same property element.) |
Maximum and minimum length of beam & IDs. |
Number of TH-selected beams. |
Number of undefined beam elements. (Element selected in TH but not defined in the model). |
Spring Element Cards |
Number of spring elements. |
The use of general spring (type 4 or 8) should be mentioned to avoid their use. |
Manual correction: Change spring into spotweld. Choose another property. |
Number of duplicate spring elements. |
Number of loose spring nodes. (If one, two, or three of the nodes defining the SPRING are not connected to another element or an RB.) |
Number of loose spring nodes. (If one or two of the nodes defining the SPRING are only connected to a same type and same property element.) |
Maximum and minimum length of spring andIDs. |
Identify null length spring elements (type 13). |
Number of TH-selected springs specified. |
Rigid Link Cards |
Number of rigid links. |
Number of duplicate rigid link elements. |
Property Cards |
Number of PIDs. |
Number of duplicate PIDs. |
Number of unused PIDs. |
Automatic delete. |
Check if the area of the truss is null. |
Open page, Selection list. |
Check if the area of the beam is null. |
Check if the inertias of the beam are null. |
Check if the inertia of the spring is null. |
Check if the mass of the spring is null. |
Check of unused properties. |
Automatic correction: delete. |
Number of Shell property(ies) with thickness <= 0. |
Manual: change the thickness of the part. |
Function Cards |
Number of functions. |
Number of duplicate functions card ID. |
Check if the function has points. |
Automatic correction: add point (0,0). Manual correction: open the page of the object which used the function. Open the page to modify the function. |
Concentrated Load Cards |
Number of concentrated loads. |
Number of duplicate concentrated load card ID. |
Interface Cards |
Number of interfaces. |
Number of duplicate interface card ID. |
Number of TH-selected interfaces. |
Interface type 2: check if search flag is "Old formulation" (value is 1) and correct it in "New improved formulation" (value is 2 or Default 0). |
Interface type 2: check of the incompatible kinetic conditions between the secondary nodes and the other RADIOSS options. |
Interface type 2: check if the spotflag is set to 0 for the interfaces that are not connections (spotwelds, glue, etc.). |
Interface type 2: check if the spotflag is set to 1 for the interfaces which are connections (spotwelds, glue, etc.). |
Interface type 2: check if the secondary nodes can be projected on the main surfaces. |
Open page, LoadCase / Interfaces / Modify. |
Interface type 2: check if a secondary node is defined in several interface type 2. |
Interface type 2: check if a secondary node is defined in the main surface of the same interface. |
Empty secondary node group or secondary surface. |
Empty main surface. |
Rigid Wall Cards |
Number of rigid walls. |
Number of duplicate rigid walls card ID. |
Number of TH-selected rigid walls. |
Rigid Body Cards |
Number of rigid bodies. |
Number of duplicate rigid body identifier number. |
Number of main nodes on structures. Non-free main node of rigid body. A rigid body main node must not be part of an element. |
Open page, Mesh-Editing / Rigid Body / Modify |
Number of duplicate secondary nodes. Nodes which are secondary nodes of several rigid bodies. |
Number of TH-selected rigid bodies. |
Check of the spherical flag according to the number of slave nodes and inertias of the rigid body. |
Automatic correction: set spherical inertia. Manual correction. Open page, Mesh-Editing / Rigid Body / Modify |
Only 0 or 1 secondary node(s). |
Main node is also secondary in the same rigid body. |
Common main node between several rigid bodies. |
Open page, Mesh-Editing / Rigid Body / Modify Automatic correction. |
Cascades of rigid bodies. |
Main node is defined inside the secondary node group defined by box. |
Rigid body main nodes are not the same as the rigid body identifier number. |
Added Mass Cards |
Number of added masses. |
Number of non-structural mass nodes. (Added mass on nodes not belonging to an element). |
Open page, LoadCase / Added Mass / Modify. |
Number of duplicate added mass card ID. |
Initial Velocity |
Number of initial velocities. |
Check if the ALE option T+G is set in the initial velocity instead of TRA. |
Number of duplicate initial velocities card ID. |
Imposed Velocity Cards |
Number of imposed velocities. |
Number of duplicate imposed velocities card ID. |
Imposed Displacement Cards |
Number of imposed displacements. |
Number of duplicate imposed displacements card ID. |
Rivet Cards |
Number of rivets. |
Open Connections / Disconnection / Rigid Bodies, Rivets & Springs window. |
Number of duplicate rivets card ID. |
Section Cards |
Number of sections. |
Number of TH-selected sections. |
Number of duplicate section card ID. |
Local skew definition (if the three nodes are defined and not set on the same line). |
Cylinder Joint Cards |
Number of cylinder joints. |
Number of duplicate cylindrical joint card ID. |
Number of TH-selected cylinder joints. |
Part and Subset Cards |
Number of parts. |
Number of TH-selected parts. |
Number of subsets. |
Number of TH-selected subsets. |
Number of duplicate parts card ID. |
Number of duplicate subsets card ID. |
Time History Cards |
Number of duplicate TH card ID. |
Check if one element is defined in several TH groups. |
Xelem Cards |
Number of Xelem. |
Number of duplicate Xelem ID. |
Accelerometer Cards |
Number of accelerometers |
Number of duplicate accelerometer ID. |
Number of TH-selected accelerometers. |
Monitored Volume Cards |
Number of monitored volume. |
Number of duplicate monitored volume ID. |
Number of TH-selected monitored volumes. |
Connections |
Number of connections. |
Number of duplicate connection ID. |
Connection: Spotwelds |
Number of spotwelds. |
Number of duplicate spotwelds ID. |
Check if there are uncreated spotwelds. |
Automatic correction Manual correction: Open the page, Connections / Spotweld / Modify. |
Connection: Bolts |
Number of bolts. |
Number of duplicate bolt ID. |
Check if there are uncreated bolts. |
Automatic correction. Manual correction: Open the page, Connections / Bolt / Modify. |
Connection: Welding line |
Number of welding lines. |
Number of duplicate welding lines ID. |
Check if there are uncreated welding lines. |
Automatic correction. Manual correction: Open the page, Connections / Welding Line / Modify. |
Connection: Glue |
Number of glues. |
Number of duplicate glues ID. |
Check if there are uncreated glues. |
Automatic correction. Manual correction: Open the page, Connections / Glue / Modify. |
Connection: Hemming |
Number of hemmings. |
Number of duplicate hemmings card ID. |
Check if there are uncreated hemmings. |
Automatic correction. Manual correction: Open the page, Connections / Hemming / Modify. |
Node Groups |
Number of nodes groups. |
Number of duplicate node groups. |
Surface Groups |
Number of surfaces groups. |
Number of duplicate surface groups. |
Line Groups |
Number of lines groups. |
Number of duplicate line groups. |
4-Nodes Shells Element Groups |
Number of shell element groups. |
Number of duplicate shell element groups. |
3-Nodes Shells Elements Groups |
Number of shell elements groups. |
Number of duplicate shell elements. |
Brick Elements Groups |
Number of brick elements groups. |
Number of duplicate brick elements groups. |
Beam Elements Groups |
Number of beam elements groups. |
Number of duplicate beam elements groups. |
Springs Elements Groups |
Number of springs elements groups. |
Number of duplicate springs elements groups. |
Truss Element Groups |
Number of truss element groups. |
Number of duplicate truss element groups. |
Segment Groups |
Number of segment groups. |
Number of duplicate segment groups. |
Dummy Cards |
Number of dummies. |
Number of duplicate dummies ID. |
