Adding More Data Tables Using the Data Table Editor Layout
You can add several data tables that you can use to build the different visualizations and parts in the dashboards of a workbook.
1. On the Data
Table panel, click
The Data Table Editor view displays.
2. On the Data Tables pane, click
and select New Data Table:
A new data table is added in the list (i.e., Datatable 1) and the Data Table Editor view changes to display the enabled Data Table Settings and Data Sources panes.
3. Repeat steps 2 to 9 of the Adding a New Data Table section.
