Adding a Numeric Action Slider
The Numeric Action Slider allows the entry of a numeric parameter.
Whenever the slider value is changed, the associated action is executed.
1. After double-clicking or drawing a rectangle
on the dashboard canvas, click
on
the Select Part pane then click the Numeric Action Slider
icon.
The Numeric Action Slider pane is displayed, and the Numeric Action Slider part is added on the dashboard canvas.
For
this example, the following parameters are defined:
Parameter Name |
Type |
Default Value |
Ticker |
Text |
COST |
Slider Value |
Text |
0 |
These parameters are used on the Title of the Line graph (e.g., Price History for {Ticker} with Slider Value = {Slider Value:0.00%}).
2. The numeric action slider can be configured to either be a Standalone or a Form component.
When set to Form, the numeric action slider can be connected to any form controller on the same dashboard. The parameters that the action part can set depends on how the form is configured.
NOTE |
An action form part must be defined first to associate the numeric action slider as a component. Refer to Adding an Action Form more information.
A line connects the component to the associated form.
If the numeric action slider should not be connected to a form, it can be set to Standalone instead. Select the Target Parameter that will be updated by this action part.
3. Enter the Title of the numeric action slider.
Otherwise, if left blank, the title of the control will be Set <Target Parameter>.
4. Select the Label Position: Left or Top.
5. Select the Label Width:
· Auto, or
· Fixed then enter the width (default is 15).
6. You can opt to enter the allowed Minimum and Maximum values.
7. Enter the Format that the numeric value will be displayed.
8. Tap the Display in PDF slider to turn it on and include the numeric action slider in the PDF output.
9. To set the style of the Numeric Action
Slider, click Style
The page updates to display the Style pane.
10. Set the Font type, size, style (Bold and/or Italic) of the part and title.
The part title’s font is set to Bold by default.
11. Click the Foreground or Background box to display the Color dialog and set the slider color or enter the Hex color code.
12. Click Update Style
and select any of the following
options:
· Set current as default – Save the changes and set it as the default.
· Create custom style – Save the changes and set it as a custom style.
The Style pane updates to display the Title control.
¨ Enter the custom style Title.
¨ If there are additional changes made, click Update Current Style in the Update Style drop-down.
The new custom style is added in the Workbook > Theme > Custom Styles list.
If published, the custom style configuration of the Numeric Action Slider will be added to the Global custom styles list and can be applied to other parts.
· Reset to default – Revert to the original default settings.
13. Click the
Save
icon on
the toolbar to save the changes.
When saved,
the
notification
is displayed.
