Altair® Panopticon
Selecting and Defining the Data Connector File Source
Several connectors including JSON, MS Excel (legacy), Text, and  XML, allow selection from a File, Web URL, or Text source.
Select the connector file source:
q  File
You can either:
·         Upload a data source snapshot by clicking Upload File  then Browse  to browse to the file source.
After selecting the file, it is displayed with the timestamp of the snapshot.
The data source is placed in the repository and locked, synchronized, and bundled with the workbook version.
To change the data source, click  then Browse  to browse to a new version of the file, which is uploaded into the repository, and also create a new version of the workbook that reads it.
·         Link to a data source file by clicking Link to File  and entering a File Path.
Ensure that in a cluster, you need to use a a shared path, or put it on every node and use a path that resolves on every node. You can update its contents whenever you want.
q  Text
Then enter the text block to be parsed.
   NOTE
The Text file source is not available for the MS Excel connectors.
q  Web URL
The dialog changes to allow specification of the following:
Property
Path
The absolute path including the http where the file is located.
Proxy Server URI
The HTTP Proxy setting that will allow the connector to reach the endpoint.
Headers
·         Headers are separated by a comma
·         Each Header is entered as Name = Value, where Name and Value can be enclosed in double quotes to allow inclusion of any character except for double quotes
·         Name and Value can also be left unquoted, in which case they may not include comma or equals characters
Content Encoding
Select the Content Encoding with the HTTP Header: None, GZip, Deflate, or GZip and Deflate
User Id
The user Id that will be used to connect to the connector’s service.
Password
The password to connect to the connector’s  service.
Check the Show Characters box to display the entered characters.
HTTP Method
Select the appropriate HTTP method for the request from the following options:
·         GET – retrieve data
·         POST – add new data
·         PUT – replace existing data
·         DELETE – remove existing data
Timeout
The length of time to wait for the server response (10 to 300). Default is 10.
Request Body
The Request Body for the HTTP POST.
Content Type
The required Content Type. Default is application/x-www-form-urlencoded
Record Path
The record path that will be queried by the connector’s path (e.g., myroot.items.item).
