Deleting Data Sources
Users with an Administrator or Designer role can delete data sources using the toolbar or context menu.
1. Check the box of one or several data sources either on the Grid View or List View.
2. Then select either:
· the Remove icon on the toolbar
· Remove on the context menu
A notification message displays.
For a data source, the corresponding applications that will be impacted is listed:
For several data sources:
3. Click
to
remove.
